Hoover HDI1L038B-80
Home Forums Trade Technical & Spare Parts Forums Hoover HDI1L038B-80
  • #102569
    Payney
    Hi, I need some help with this one if there are any Hoover/ Candy engineers. Does anyone have a service manual or fault codes for this model. I have one that at start up constantly drains then after a while flashes Program 3 light. This machine has not got a flood switch and has no leaks. Any help will be much appreciated.
    Thanks in advance.
    #489483
    well no fault codes listed on the tech site
    hoover dont make these and never have made dishwashers
    I would check pressure switch first
    dave
    #489484
    baron
    Perhaps it has drain related problem (error E3).
    Beside PCB related, verify pressure level switch, heater and safety switch (41901973 part.) .
    After resolving possible issue, in order to pass this stage you have to open the door, keep PROGR button pressed for 3 sec and close the door and wait…
    #489485
    baron
    electrofix wrote: well no fault codes listed on the tech site
    dave
    Candy?
    I’m remember this kind of heating/water pressure control sistem on late 20 years ago…
    #489486
    baron wrote:
    Candy?
    early dishwashers were Fagor built I think
