Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hoover HDPN 1S543PX-80 Error 03
- This topic has 13 replies, 2 voices, and was last updated 4 years, 8 months ago by
Murphwiz.
August 1, 2021 at 2:42 pm #99875
Murphwiz
ParticipantHello, I’ve got problem with my Hoover HDPN 1S643PX-80 Error 03.
it shows error 03 on drain, drain pump up runs, and I’ve pulled hose out and verified it actually drains, but put won’t stop.
any ideas where to look for the problem?
recently every few washes it does leave a stale smell, so it could be retaining water I guess.
any tips or pointers would be great, before I battle it from under the counter.August 1, 2021 at 2:59 pm #478259electrofix
Moderatorcheck that model no as i cant find it
August 1, 2021 at 5:55 pm #478260Murphwiz
ParticipantThanks Dave, typing error on my part, but I can’t update title, it should be:
August 1, 2021 at 6:06 pm #478261electrofix
ModeratorI checked and E3 is a drain fault
its either a blockage in the drain or in the pressure system that detects the water
August 1, 2021 at 8:30 pm #478262Murphwiz
ParticipantMany thanks.
I pulled drain pipe and did a quick rinse cycle, plenty of water came out, then stopped but pump carried on before E3 beeped.
so guess pressure sensor thinks water hasn’t finished draining.August 1, 2021 at 9:12 pm #478263Murphwiz
ParticipantIs there a spec for the sensor, so I can check it?
August 1, 2021 at 9:21 pm #478264electrofix
Moderatorthe sensor is air operated so first check for blocked pipes
switch part no should be 41030820
if you google it you can see what it looks like
August 2, 2021 at 6:12 pm #478265Murphwiz
ParticipantMany thanks, will take look.
August 3, 2021 at 7:01 pm #478266Murphwiz
ParticipantRemoved sensor, there was a little water in the pipe.
gently blew into sensor, can hear switch move.
with a multimeter, no pressure, it’s open circuit, blow into sensor, changes to 0 ohms.blew into sump, that seems clear, blew down outlet hose, that ‘blocked, removed hose, appears to be a one way valve on the body, so appears normal.
any thoughts.August 3, 2021 at 7:08 pm #478267electrofix
Moderatorhave you tried it again after that ?
August 3, 2021 at 8:10 pm #478268Murphwiz
ParticipantNot yet no, just debating what else could cause it.
August 4, 2021 at 5:57 pm #478269Murphwiz
ParticipantRuns couple of cycles, seems to be working fine.
is the water in the pressure pipe enough to fool the switch?August 4, 2021 at 6:04 pm #478270electrofix
Moderatorcould just be the switch stuck and you have freed it
August 4, 2021 at 8:58 pm #478271Murphwiz
ParticipantThanks for the pointers.
will give it a couple more runs, and stick it back under the worktop. -
