Hoover HFA 27k
  • #45532
    timjam
    i have gone to do a pcb change on this unit and it asks for a PF Type number to remove jumper tags from pcb. The type number is not on the configuration list. I have left them on but the unit will not start! , does anyone have any ideas ????
    Model number hfa27k
    #286012
    loopey
    Re: Hoover HFA 27k
    hope this helps
    these units can take up to 10 mins to get going ?
    #286013
    timjam
    Re: Hoover HFA 27k
    that sheet came with the pcb, but this f/f says type 27/11 which isn`t on there
    #286014
    loopey
    Re: Hoover HFA 27k
    give me the product number will have a look in the advance search option 🙂 see iff owt pops up
    #286015
    timjam
    Re: Hoover HFA 27k
    3300023 0329 0424 type 27/11 thanks
    #286016
    loopey
    Re: Hoover HFA 27k
    nothing found on gias site 🙁 so i rang the techey guy he said both jumpers should be on , and or check against old pcb ? all so check toc in freezer iff o/c it wont do a defrost and throw up a fault code i/e flashing green and orange lights on front panel : hope this helps
    phil
    #286017
    timjam
    Re: Hoover HFA 27k
    ok thanks
