Hoover HFA270 fridge freezer freezing in the fridge
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HFA270 fridge freezer freezing in the fridge
  • #53692
    Fairdeal
    Hi Guys,
    had this job come in a month ago where customer complained that the food in th fridge is freezing and vegetables are goin off, this one has thermostat fitted onto the PCB so I replaced the PCB andafter three weeks he is complaining again about the same issue, I could not find any probe for temperature
    Any Ideas?
    regards
    omar
    #316854
    pup
    Re: Hoover HFA270 fridge freezer freezing in the fridge
    i sure there is one buit in at back you got to dig out form
    #316855
    loopey
    Dimension H (measured from the top
    edge of cabinet): 168 mm.
    Dimension L (measured from the left
    side edge of cabinet): 172 mm. at the rear when condenser has been removed …
    hth phil
    #316856
    Fairdeal
    thank you do you know if they do the probe as a spare part? if so if you have part no please let meknow thanks very much
    #316857
    loopey
    49003477 going to send you a little some thing all i need is a email address
    #316858
    loopey
    should be some thing in yer in box 🙂
