Re: Hoover HFA27K Fridge not cold enough
..Go on get me into trouble…
Common fault is that over a period of time ice builds up and blocks th evaporator… By moving the defrost sensor that would normally be on the bottom right of the evaporator and cable tying it to the very top centre.This will therefore allow a slightly longer defrost which would normally cure the problem.
Defrost the complete unit for 36hrs with the freezer door open before moving sensor.
Bryan
