Re: Hoover HFI 3015 Not Working.
In the end I took out insurance and made a claim. They sent a repair guy and at first he could not find the fault. He then replaced the circuit board and when that didn’t work, he discovered a broken wire in amongst the loom that runs out from the base of the door. Apparently its a common problem as over time with the action of opening and closing the door, it causes the wires to fracture. It could have been worse as there was no covering protecting the loom, so if it touched the metal door, it could have caused an electric shock. So maybe you have a broken wire in the loom.
