Hoover HMC131
  • #33183
    DentedPorsche
    Hiyas,
    My posts are a bit like busses. Nothing for ages and then a lot together. 😛
    Anyways, this one is doing my head in. It goes through the wash ok, rinses ok and spins ok, then it repeats the spin. If you let it keep going it just keeps repeating the spin cycle.
    All the usual checks, heater, motor and what have you are fine, can’t find anything wrong. Pressure system is clear and pressure switch is switching.
    The pcb has been replaced and no difference.
    Any ideas? Any help? Everything is, as always, gratefully received.
    Brian
    #237722
    suedehead1
    Re: Hoover HMC131
    hi, i had exactly the same problem and it was the pcb, if you have changed it and it makes no difference tighten all the connections on the pcb or try a slave timer.
