Hoover HNC 5174W not freezing
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hoover HNC 5174W not freezing
  • #73043
    Monkeymonks
    I have a Hoover HNC 5174W fridge/freezer. The Fridge is cold but the freezer isn’t cold enough. There is only one temp control and that is inside the fridge. I assumed that this controlled the freezer and that cooled the fridge. But all it does is make the fridge colder to the point of freezing and the freezer is still above zerio degrees. Any ideas? Thank you.
    #386278
    Hownowfi
    Mine doing the same, so will be interesting to see if you get any replies.
    #386279
    Tony R
    Check fan working in freezer, and its not iced up at the rear of freezer
