Hoover HNC160-80
  • #29228
    effzedarr
    The above m/c just stopped according to the customer. When pressing the on/start button ,neon lights up ,relay seems to click & timer starts to click but thats it ,heater checks out ok but no mains supply down to it, am I looking at a timer or is it the little circuit board/ relay thingmy jig? Couldn’t do anymore tests as customer wanted to go out [why do they do that?], s/n 31100067 0436 5325.
    Regards Chris…
    #222414
    whiskeyjack6058
    Re: Hoover HNC160-80
    Not had that one before, but the pcb’s do fail for fun, usualy causing the dryer to stop running unless the start button is held in. I hate these poxy hoover dryers, will be glad when there a thing of the past. Especially the condensor version that squeek rattle and cause so much greif! If the door switch is ok then I personaly would go for the pcb for what it costs (£6.51+vat from connect distribution). After all, it’s a common thing to fail and there are millions of these evil contraptions around so if it isnt the pcb, you will use it on another job before long.
    #222415
    PCB is purely a start relay device and has nothing to do with the heater circuit.
    Assuming that the heater stats are in circuit, there is another one on the front by the drum wheel support bracket that can play up – lots of broken wiring in that area due to inadequate restraint of the loom. If that checks out, yes, timer – it’s all that’s left.
    Jack – quoting Connect prices in the forum is a bad plan. Your £6.51 is probably somebody else’s £6,510,000 due to their iniquitous pricing policy. Sufficed to say, I know longer enjoy a business relationship with them. Didn’t enjoy it much when I had a business relationship with them………..
    effzedarr
    Chers chaps, will try pcb, if its owt else I think the customer will go for a new ‘un just to match her washer [how vain!].
    Chris…
    #222417
    effzedarr
    Well been back today & it ain’t the Relay PCB as Chris predicted, so its looking like a timer huh? Trouble is Spareslink & Connections don’t show one, any body got a part # please…
    Regards Chris…
    #222418
    helo_75
    nope, itll be the float switch? ive had a few, and they do that and it been a sticky float switch
    good luck getting to it
    #222419
    effzedarr
    Oh by that you mean its a b*gger to get at?
    Chris…
    #222420
    helo_75
    oh yes, front off, drum out
    not nice at all
