Hoover HNC380-80 condenser dryer, stopping after reversing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HNC380-80 condenser dryer, stopping after reversing
  • #59468
    Bernie
    Hoover HNC380-80 condenser dryer, stopping after it has done a reverse tumble, programme cancelled.
    It does not matter what programme it is on ‘timed’ or ‘sensor-dry’ after it has done a reverse tumble the programme is cancelled.
    When you open the door there is heat there so I guess the stats and heater are ok
    I did find on this site somebody had similar problem but that was with a Hoover HNC382T-80 the front exhaust stat at filter housing. nc85 degrees sorted that one.
    Is it that or the pcb? If it is the stat would you know part number?
    Any help and advice much appreciated.
    Bernie
    #338277
    Bernie
    Re: Hoover HNC380-80 condenser dryer, stopping after reversi
    Please
    Does anybody know the part number for the programmed PCB?
    I found a part number for the unprogramme one.
    Also the part number for the exhaust stat.
    Thanks Bernie
    #338278
    loopey
    hoover p/n 40003568
    connect p/n 5045173401822
    hth
    #338279
    Bernie
    Thank you very much Loopey
    Bernie
    #338280
    loopey
    no probs 🙂
    Also the part number for the exhaust stat will get to that for you iff you still need it missed it on 1st read was on me phone lol .
    phil
    #338281
    Bernie
    I was given part number 40003336 but it was the wrong one.
    I do still requirer the part number for the exhaust stat, if you would not mind.
    Thank you Loopey
    Bernie
    #338282
    loopey
    40003258 NTC probe
    5045171534522
    there you go 🙂 i think thats what you need
    #338283
    Bernie
    Thank you once again Loopey
    Bernie
