Hoover HND315 80
  • #27924
    effzedarr
    Hi ,need a part # for the bit that holds the slim pcb module [which allows you to select temps & halfload],its a white plastic affair which the pcb clips too in the door.
    Regards Chris…
    #216106
    helo_75
    had a few of those break, u need to order the pcb complete
    could use the right product number (1st 8 digits of serial!!!)
    #216107
    effzedarr
    Re: Hoover HND315 80
    Hi Helo,numbers are32000083 0446 3702.
    Hope thats of some use.
    Chris…
    #216108
    helo_75
    well, according to gias website,(and theres an actual pic!) its shows it as the pcb, with 3 leds and other things, with a slim white plastic piece attatched to it, which then screws on to the bezel.. is that it?
    if it is, the part number is 41010331
    id ask hoover first… but its quite new that, cant be over 12 mths old?
    #216109
    effzedarr
    Don’t know about its age but what happened was one of those little switches on the PCB broke off & got stuck behind one of the push-buttons & the customer must have pressed the button again & bust the plastic retaining part! I’ve resoldered the switch back on the PCB I just need the plastic part, seems a bit of an expence buying the whole board, but hey ho thats manufactures for you!
    Cheers anyroad, Chris…
    #216110
    effzedarr
    Oh well pt#41010331 didn’t come with said plastic part just the pcb, sorry for delay customer on hols.Had to use soldering iron to bend broken tags over pcb ,fingers crossed it should hold but would like pt# for this bit sometime. Regards Chris…
    #216111
    helo_75
    grr, hoover dont list that part, ill see if i can dig it out for you :@
    #216112
    effzedarr
    Cheers m8y….. 😉
