Any help appreciated. First fault was that filled, wash pump kicked in then fill,wash and drain all at once in a rythmic all on all off cycle. everything mega’d ok so changed module in door. Now nothing works only the salt light as you turn on and off. Refit old module and machine reverts to working but with fault. Am I right with needing a module? If so have I a faulty new module or do I require a display board also?
