Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hoover HND6515
- This topic has 13 replies, 5 voices, and was last updated 16 years, 3 months ago by
deewarren.
January 11, 2010 at 2:10 pm #51546
deewarren
Participant——————————————————————————–
Hi All,I’m not sure if anyone can help but I have a Hoover HND6515 dishwasher, and it’s developed a fault. It stops full of water after doing a pre-wash cycle and the program led on the front flashes quickly, also the machine is constantly beeping. After powering off and cancelling the program a new program can be selected and the machine will then start but only gets to the same point of a rinse cycle and then beeps and flashes. The pre rapid programme works fine, goes through wash , rinse and dry, its the main proogrammes that dont work, therefore there is no blockage , can anybody help, thanks
January 11, 2010 at 6:24 pm #308481Penguin45
ParticipantRe: Hoover HND6515
Does it heat on the Rapid programme?
January 11, 2010 at 6:53 pm #308482deewarren
Penguin45 wrote:Does it heat on the Rapid programme?
hi, rinse water from raid programme was cold, even though this programme is for short wash at 50 degrees
January 11, 2010 at 7:20 pm #308483Penguin45
Rapid programme runs against time – the others run against temperature, therefore you have some sort of heat problem.
Element, sensors, safety cut-out, wiring and burnt out joints on the pcb are all possible faults.
Power off if you intend to investigate this yourself.
January 20, 2010 at 5:21 pm #308484bryanh
I was just wondering if you managed to repair your dishwasher. I have exactly the same problem on exactly the same dishwasher. Mine stops on the normal cycle after 35 minutes but completes fine if you select the rapid wash. 😕
January 20, 2010 at 9:32 pm #308485deewarren
hi, dishwasher the same,i tried to find the element , but cant find it or any wires to one, as the element should be at the bottom somewhere, so it has foxed me. the temperature sensor i have found, but i was relying on replacing element first as it reminds me of an element in a kettle, and these do go, how long has your problem existed? i can get the dishwasher repaired by hoovers for £110, as the parts are covered by guarantee, but i think this is a lot of money when i only paid £220 for it in the first place, so it looks like it will be skipped, let me know if you ever get yours fixed, thanks
January 20, 2010 at 10:20 pm #308486Penguin45
Element is in the up tube to the top rotors. Remove plastic cover at the bottpm to reveal terminals.
Power off first.
February 3, 2010 at 11:55 am #308487goforth
ParticipantHi
I have the same problem …. can anyone help? Where is the NTC Sensor located, is it easy to find / replace , or could it be the element – dont want to call out an expert but fed up of dishwashing by hand!!! ! 😳 😳
February 4, 2010 at 12:10 am #308488Penguin45
The basic information is in the posts above. Go forth and test (with the power off).
March 14, 2010 at 1:25 pm #308489tonto53
I too have the same problem and would like to know how to locate the NTC, I did check the posts above as suggested, but couldn’t find any specific info. Any guidance deeply appreciated.
March 14, 2010 at 5:35 pm #308490deewarren
hi, the sensor is located behind the right side panel as looking from the front, you will have to remove top to get at screw to the side, also the previous person replaced the sensor and it didnt fix the problem, i suggested the element but i dont know if they replaced that as i didnt receive an answer from them, if you get it fixed, let me know what was wrong with yours, thanks
March 15, 2010 at 5:57 pm #308491tonto53
Thanks Dee, I removed the right hand panel as suggested, but can’t see any obvious ntc, picture link below if that helps you point me in the right direction.
http://picasaweb.google.co.uk/113461858511564751125/Desktop?feat=directlink
March 15, 2010 at 7:59 pm #308492Penguin45
NTC sensor is fitted to the front outside of the sump moulding.
March 16, 2010 at 10:21 am #308493tonto53
Thanks Penguin, I removed and tested the ntc, that seemed to perform as expected at room temp and when hot. Disconnected and checked the element, 200+ohm so assuming its OK. Hands getting all chapped from washing up so I’ll probably surrender now and get a new machine. Thanks to all for the help – always interesting to take something apart.
