Hoover HNF2127-80 constant draining
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HNF2127-80 constant draining
  • #81643
    OLLIE2806
    31000638 0428 2137
    The above washing machine wouldn’t drain, turned out to be prog selector sticking which I replaced, all seemed fine but after 1 wash (which it went through fine) all it does is drain? You turn the prog selector and before you even press start it starts draining?
    I’ve checked the insulation as a whole & on the motor & element individually, pressure switch seems to fine. Are these just a 1 level switch (as in 1 click) I found a sock in the sump but that hasn’t changed anything?
    Should I be looking main pcb or am I missing something?
    #417264
    Re: Hoover HNF2127-80 constant draining
    from the sound of it the triac that controls the pump is short circuit on the pcb
    simple swop if you can solder
