Hoover HNF2137-80 door lock light keeps flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HNF2137-80 door lock light keeps flashing
  • #45897
    Bernie
    I have a Hoover HNF2137-80 that the door lock light keeps flashing. I did go to this machine two days ago with the same fault but found when I tightened the connections to the PCB it worked ok, the customer got two washes out of it before it packed up again. I have checked the door lock and I get a supply coming out of it after it has locked and to the PCB.
    Is it a new PCB?
    Thanks Bernie
    #287561
    timdowning
    Re: Hoover HNF2137-80 door lock light keeps flashing
    Does the machine do anything, fill, pump???
    I’ve never had the door lock light flash. Are you sure its not one of the option lights flashing? Is there a pattern of flashes?
    Normal hoover codes for that range are a certain number of flashes in a 15 second period.
    #287562
    Bernie
    yes doorlock led flashing does not do anything else, have not counted the flashes.
    bernie
