hoover HNF3147-80 3100636 wont spin but washes ok
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hoover HNF3147-80 3100636 wont spin but washes ok
  • #89865
    alro
    Hi gents washes fine and heats up but will not go into spin on any programme
    if you put on spin only it pump comes on and as motor rotates the relay on board clicks out pump goes off and display goes to stop and door will unlock i suspect programme selector more than pcb anyone had this fault ( not pressure system blocked) cheers alro
    #442795
    smartin
    Re: hoover HNF3147-80 3100636 wont spin but washes ok
    check heater isnt down to earth, failing that probably pressure switch i would say.
    #442796
    kaibart
    It’s a dc machine check the rectifier these are prone to more than1 fault
    #442797
    alro
    why should it wash ok but not spin cheers alro
    #442798
    kaibart
    Hoover used to have 3 problems with dc machine rectifier motor or main pcb if you want to check selector but it through a test cycle if you have problems getting it going into test more than likely selector
    #442799
    alro
    tried a selector machine still same fault looked at rectifier no sign of damage as machine washes ok but will not spin dont suspect rectifier now i suspect core board any help will do cheers alro
