Replaced coreboard to cure not starting.Machine starts,will fill and drain but no motor action.Checked motor out ok.Other than than loom continuity is there anything else lurking that I should check
winker wrote:Replaced coreboard because machine would not start cycle.Starts ok but no motor action on wash or spin.Checked motor,loom and tightened all connections but still the same.Two questions.How likely is the module to be faulty and are their any GIAS engineers on here.
