Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover HNF7148 Blown Board?
- This topic has 8 replies, 5 voices, and was last updated 13 years, 2 months ago by
Profyaffle.
February 6, 2013 at 9:13 am #73994
Profyaffle
ParticipantHave one of these with no pump action. Put a new board in and it worked for approx. 10 washes and now doing the same thing…. Help!! What can cause the Pump circuit on this one to go Faulty, causing the Board to go? Chris
Checked Usual… Heater, Motor Brushes, Selector??February 6, 2013 at 9:47 am #389557aqualectric
ParticipantRe: Hoover HNF7148 Blown Board?
Small condensation leak from tub runs round and drips DIRECTLY on the pump coil – fantastic design. Firstly, change PCB. Then before using it, change pump and cover with a plastic shield. It was mooted a while back that the Gias engineers used to put a line of silicone on the side of the tub to draw the water away to the back of the machine to stop recurrence.
It will have blown triac No 5 on the board and if you are lucky you may be able to salvage a triac off the old PCB and swap it out. If unlucky….new PCB.HTH,
Steve.
P.S. This should be posted in Tech Enquiries – keeps it all neat and easier to find in future. 😉
February 6, 2013 at 10:02 am #389558iadom
ModeratorRe: Hoover HNF7148 Blown Board?
Moved. :rolls:
February 13, 2013 at 8:31 pm #389559Profyaffle
Thank you
February 14, 2013 at 10:37 pm #389560smartin
also glue in the dispenser to tub hose, which enters the tub directly under dispenser, you will probably find it fits very loose because of tub movement over time.
February 14, 2013 at 10:44 pm #389561iadom
Worth checking/changing the connector to the pump as well. This connector often burns across the terminals.
Sent from my iPad using Tapatalk HDMay 13, 2013 at 7:45 pm #389562AMS
I went to one of these with no pump action too. Also, no water intake. Pump itself checks out, and wiring to it. Valve solenoids good too. The obvious thing to go for is the module(41021514). Not too expensive, but Connect and Masterpart show it as unprogrammed. What is involved in programming it?
May 14, 2013 at 8:48 am #389563AMS
Anybody?
May 16, 2013 at 7:31 am #389564aqualectric
Get Connect to do a PNE for a programmed one…… 😉
Steve.
