Re: Hoover HNF7167 main board dead?
tootancarmoon wrote:So I suspect the solenoid failed and has taken out the main board.
Anybody seen this kind of fault and can confirm likely diagnosis.
Your diagnosis seems very plausible. Confirmation can easily be established by carefully inspecting the triac in question. It’s usually the one that has blown its black plastic cover. The other triacs have an identical ratings so the component number can be read from one of them if you wish to try sourcing one. Maplins, Farnell, Radiospares etc……
A word of caution though, finding a blown triac might not be the only failing of the PCB. Other factors may give rise to the faults like this. It is a Hoover after all said and done don’t forget. 😉
