Hoover HNF7217 wont spin!!!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover HNF7217 wont spin!!!
  • #54329
    bg2128
    My washing machine wont spin, at first it wouldn’t drain, have drained the pipe that goes into the u bend manually. Thinking that it would spin, but it still wont work. Any help would be appreciated.
    #319235
    odom
    Re: Hoover HNF7217 wont spin!!!
    I assume you mean HNF7127?
    Are you sure all the water has been drained out? Just because you can’t see any in the drum doesn’t mean it’s all gone. Check by removing filter (behind kickplate at bottom of machine) – be ready with a bowl. While you’re there thoroughly clean filter check pump for obstructions – including right at the back with a torch. Pump impeller should turn around reasonably easily. Any water left by blocked filter would activate pressure switch and prevent machine from spinning.
    If it’s still not working check sump hose and waste pipe for blockages.
    If it still doesn’t work check motor carbons, pressure switch then module..
    Let us know if you still can’t solve the problem.
