Hoover HNL 6166-80 FL no heat Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover HNL 6166-80 FL no heat This topic has 4 replies, 3 voices, and was last updated 12 years ago by Twoten. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts April 9, 2014 at 4:24 pm #80264 TwotenParticipant Called to the above machine due to water not heating. The element and wiring loom check out OK. The resistance across the NTC is 33? and again loom is OK. The heat and temp selector switches are the same so I swapped the over to eliminate the selector. Is no heat a known problem for the modules on this machine? Thanks. April 9, 2014 at 5:10 pm #412291 MartinParticipant Re: Hoover HNL 6166-80 FL no heat Twoten wrote:Is no heat a known problem for the modules on this machine? A common failing, on any make, why the relay on the module should fail I would say. April 9, 2014 at 5:23 pm #412292 CriscoldParticipant Re: Hoover HNL 6166-80 FL no heat Re-Check NTC Resistance Ohmic values of NTC Probe are: 20 Kohm at 25°C – 2.14 Kohm at 85°C. April 9, 2014 at 9:17 pm #412293 TwotenParticipant Re: Hoover HNL 6166-80 FL no heat Criscold wrote:Re-Check NTC Resistance Ohmic values of NTC Probe are: 20 Kohm at 25°C – 2.14 Kohm at 85°C. I will check the NTC again. April 10, 2014 at 7:43 pm #412294 TwotenParticipant Re: Hoover HNL 6166-80 FL no heat Thanks Criscold, I double checked the NTC, at ambient (which today was about 12°c) the resistance was about 30kohm. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
