Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover HNL 6166 – stops midway through cycle
- This topic has 7 replies, 3 voices, and was last updated 16 years, 1 month ago by
wizard_of_odds.
February 21, 2010 at 2:23 pm #52676
wizard_of_odds
Participantmay not be exactly midway as there is no way to tell where it is in the cycle.
The door lock remains on and the start and delay start lights flash.
Only way out is to switch of & back on & restart programme – machine then completes wash.
problem is intermittent at the moment.
Any thoughts / advice would be appreciated (my guess at any replies would be “electronic board” 🙂 but confirmation would be good)
thanks
February 21, 2010 at 2:24 pm #312711Penguin45
ParticipantRe: Hoover HNL 6166 – stops midway through cycle
Any pattern to the flashing? ie 1-2-3-4-pause-repeat.
February 21, 2010 at 3:05 pm #312712wizard_of_odds
chief engineer says the start & delay start lights flash alternately – I will wait until it does it again & observe further
NEW – CE says the pump has stopped pumping now – could be the pump?
February 21, 2010 at 3:48 pm #312713helo_75
Participanttheres a very good chance there is an obstruction in the pump/pipework, yes
February 21, 2010 at 3:56 pm #312714wizard_of_odds
cleaned the filter – I can check the pump if someone can give me a clue as to where it is – i.e. which panel to remove?
February 21, 2010 at 4:10 pm #312715helo_75
Participantattatched to the filter, tip it back, ull see it
February 21, 2010 at 4:28 pm #312716wizard_of_odds
Penguin45 wrote:Any pattern to the flashing? ie 1-2-3-4-pause-repeat.
ran another cycle – both lights flashing together 1-2-3 pause repeat
February 21, 2010 at 5:14 pm #312717wizard_of_odds
well,well, well – disconnecting the inlet pipe to the pump revealed a small ziploc bag lodged in the pump entry pipe!
Of course, chief engineer blames me, cheek! – however I am renowned for leaving various motorcycle parts in my jeans and the bag does resemble one that would hold such parts (the parts were not in it!)
Running a cycle to see if that was the problem but I’ll bet it was. As usual thanks for all the help, you guys came up trumps again!
