Hoover HNL6136S no spin
  • #50772
    Machine will fill, wash, drain and rotate on drain perfectly but after a couple of minutes set to a spin programme it cuts out totally and does not ramp up to distribute or spin.
    Motor fine, pressure chamber and hoses clear, pressure switch appears to be functioning correctly.
    Any other suggestions gratefully accepted. 🙂
    timdowning
    Re: Hoover HNL6136S no spin
    Does it spin when it goes through a normal cycle or is it just no spin when you try a spin cycle on its own?
    #305920
    No spin at all AFAIK Tim, she also said it seemed to be taking longer to complete but she may have just imagined that.
    #305921
    timdowning
    Well the obvious one of the spin speed selector being set to the ‘no spin’ 12 oclock position is a favourite with my customers.
    And extended time of programmes is generally down to OC heater.
    Have you seen it no spin? Or is it just reported?
    #305922
    Did check the spin speed selector. Sat and watched it go through rinse & spin. On spin it reverse tumbles for about 2 minutes then shuts down, no flashing lights either.
    #305923
    Had similar model, was o/c heater. Never would have guessed. Found it somewhere on here. Think it was Penguin pointed it out, or maybe helo.
    Mike.
    #305924
    Thanks Mike, will give it a try., would explain the extended wash times as well. 😕
    BINGO. 😀
    Heater was O/C…To paraphrase the name of a local pub…’Who’d a Thowt it’ 😆
