Hoover HNL6166-80 Bearings
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hoover HNL6166-80 Bearings
  • #40541
    Does anyone know what bearings are fitted to this machine? I have part numbers such as 07170838 and 92440122 but would like to know the bearing numbers eg 6206, 6207 etc. Alternatively, is there a bearing kit available?
    #266773
    lerch
    Re: Hoover HNL6166-80 Bearings
    91406201 Seal retainer end 0727
    41024550 Seal retainer from 0727
    09170838 Bearing
    224 24152043 Bearing
    #266774
    I will order Masterpart kit CY05103 and hope for the best. The bearings from GIAS are so expensive I could not do the repair any cheaper than GIAS would charge for a call-out.
    #266775
    Well, CY05103 was not the right kit but I do have the correct bearings in stock. They are 6205 & 6204 and the seal is the same O/D and I/D as a Zanussi 1000 spin seal but 1.5mm thicker. Going by the witness marks on the spider bush there will be adequate penetration of the thinner seal 😀
    #266776
    Phidom wrote: same O/D and I/D as a Zanussi 1000 spin seal but 1.5mm thicker
    Sounds like you might be best to put in 1.5mm of packing behind the seal before pressing it in. Maybe a suitably sized circlip or two?
    Mike.
