Hoover HNL6166 will not start
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HNL6166 will not start
  • #60990
    Bernie
    Got to go to this one on Monday customer has just moved house and machine was working ok before move.
    Now buy there description the only thing that happens is the drain pump runs for a minute or two then nothing whether it on a wash or spin program.
    I did get them to check that there is water getting to the machine they took the inlet hose off to make sure.
    Any Suggestions what to look at?
    Bernie
    #344452
    allan73
    Re: Hoover HNL6166 will not start
    Had a candy with edge connectors off the module after a house move a while back. Might be worth a check ?
    #344453
    helo_75
    agrred, theres a lip on the drum which puls the bottom edge connector off the pcb
    always happens when they been carried
    either that or they havent turned the water on
    #344454
    gandh1
    OR theres a drainage spike blocker/wodge of silicone inside the waste spike.
    is it a downpipe or spigot waste attachment???
    #344455
    Bernie
    You were spot on allan73 it was a connecter at the bottom of the PCB
    Thanks to all of you for your suggestions
    Bernie
