Hoover hnl662
  • #47794
    timjam
    i have this booked in for next week cust says that it fill then stops with the start and delay lights flashing, any ideas ?
    #294634
    loopey
    Re: Hoover hnl662
    this should help yer 🙂
    The Error Codes are displayed by making flash simultaneously the START LED and the LED
    OF THE 1st OPTION’S BUTTON
    The length of each displaying of an Error Code is 15 seconds. During this period of time, both
    LEDs flash together at the frequency of 1 Hz (1 flash per second), the number of their flashes
    in the 15 seconds period being the actual Error Code. After the Code was displayed, both
    LEDs stay OFF until the end of the 15 seconds period. Then, the sequence is repeated.
    Example: Error Code n. 2 (missing completion of the water load, within the designed limit
    time) is so displayed:
    • 2 flashes by the 2 LEDs together, in the 1st 2 seconds (0.5″ ON – 0.5″ OFF).
    • 13 seconds both LEDs are switched off.
    • The sequence as above is repeated.
    Error 1 Door Lock Safety Device open circuit and/or Wiring.
    Error 2 Missing completion of the Water Load Phase, within
    the designed limit time of 5 minutes and 18 seconds,
    due to Low Hydraulic Pressure, faulty Solenoid Valve
    and/or clogged Fill Hose
    Error 3
    Missing completion of the Water Drain Phase, within
    the designed limit time of 6 minutes, due to clogged
    Pump’s Filter and/or clogged Drain Hose or clogged
    domestic drain system
    Error 4
    3 sequential operations by the Anti-flood Contacts of
    the Pressure Switch, due to Mechanically Blocked
    Opened Solenoid Valve or faulty Pressure Switch.
    Error 5
    Faulty NTC Temperature Reading Probe and/or Wiring
    and/or “Core” Board. Ohmic values of NTC Probe are:
    20 Kohm at 25°C – 2.14 Kohm at 85°C.
    Error 6 Defective “Core” Control Board.
    Error 7 Main Motor’s Rotor is jammed
    Error 8
    Short or Open Circuited Motor’s Tachometric Dynamo
    and/or Wiring. Ohmic values of Tacho’s Coil as follows:
    Ohmic Value with Ceset Motor: 42 Ohm
    Ohmic Value with Hoover Motor: 156 Ohm
    Ohmic Value with Sole Motor: 184 Ohm
    Error 9 Short Circuited Motor’s Triac on the “Core” Control
    Board and/or defective “Core” Control Board.
    Error 10 Faulty Program’s Selector and/or Wiring.
    Error 0 Faulty Wiring and/or defective “Core” Control Board. no flashes ?
    #294635
    Re: Hoover hnl662
    All in Known Error Codes at the top of the forum…….
