Hoover HNL662 Can’t select programs
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HNL662 Can’t select programs
  • #62136
    talkingtent
    Hello I have a Hoover HNL 662 the machine was on its final spin cycle when I had to switch off as there was a coin clanging around inside. Removed sump hose found the coin replaced hose now whatever program I try to select all I get is the 15min light comes on and the pump runs no drum action then switches its self off after a few mins ? Is there a reset I can do ?? Thanks James
    #348879
    Re: Hoover HNL662 Can’t select programs
    THe only ‘reset’ is by turning the dial to the ‘Off’ position. Sounds like you may have blown the motor triac (marked TR1 on the coreboard) so best take a close look at the board?
