Hoover HNL662 PCB popped
  • #66956
    HNL622-80 31002596.
    Drain pump as dead as a Dodo, no signs of any leaks onto pump which appears to be OK but a tiny triac on the board has blown, is this likely to be just a failed board? Pump has had a few blockages but it does have an overload fitted.
    BobHope
    Re: Hoover HNL662 PCB popped
    i wood change both of them just incase, its quite a common problem but normaly you can see melted or distorted plastic on the pump.
    Bob.
    #365754
    timdowning
    Don’t forget to fit a drip cover on the pump.
    #365755
    Thanks Bob, I did quote for a new pump and was going to fit one, your reply strengthens my resolve. 8)
    I usually do cover the pumps, this one has no signs of leaks of any kind onto pump though, dispenser inlet hose well sealed.
    BobHope
    have you got the componant layouts and connection chart Jim ?, its handy as it shows which triac powers what componant, if not i can forward it.
    Bob.
    #365757
    If its document 005-LB then yes I do have it thanks. 🙂
