This machine shows no sign of life apart from the “Stop” lamp flashing. I have tried the test sequence in the fault code guide to no avail. Door doesn’t lock either. I’m suspecting the PCB – any thoughts??
All seems OK there; I have had this push button board pop out of its mounting clips before so I checked that. Start button clicks; seems alright…… 😕
Can anyone tell me if the push button PCB behind the fascia of a Hoover HNL7166 – 80 (3100197607300182) is the same as the one fitted to the HNL7126 mentioned above? It looks identical……. 😕
