hoover HNL7146 help please
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hoover HNL7146 help please
  • #78807
    skeggylad
    Hi Happy new year
    Ok New years eve my washing stopped spinning leaving clothes soggy i checked all the pipes ect they are clear the pump is ok as i did the Auto Test BUT another problem appeared while in test mode the barrel wouldnt stop filling with water i got worries so turned it of and drained it all away so i know pumps working no error codes are displaying
    if i put on drain as well it keeps draining and wont stop
    same as if i put on spin cycle the barrel just turns and drains constantly and wont go into spin
    now if i try to put on a normal cycle no water starts and the barrel turns very slow
    any ideas please or is it time for currys?
    thank you
    #406981
    Re: hoover HNL7146 help please
    Sounds as if the pressure switch or sensor is either being held open or is faulty.
    skeggylad
    Hi thanks for a quick response
    i took it off and checked it on a multi meter it seems to be doing something not sure what to check but
    #406983
    I’m not familiar with the model but I think this is the pressure switch fitted…
    http://shop.ukwhitegoods.co.uk/97921910 … ure-switch
    When you blow into it you should hear at least two or three clicks and two of the switches should close, both essentially cut the fill valves off.
    If it is jammed open then the machine would think it was full of water and just constantly try to drain never reaching the switching point where it knows it’s been drained down.
    skeggylad
    yep thats the one
    if i suck or blow get one click but i think diaphragm might be worn
    #406985
    Check that the sump hose and pressure chamber are clear as shown here…
    http://shop.ukwhitegoods.co.uk/41002867 … -sump-hose
    If they are then there’s a fair chance it’s the pressure switch but, obviously, I cannot be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain of that.
    skeggylad
    do you know what ive done a stupid thing ive took the 3 connectors off and forgot to take a picture so can put them back on arhhhh lol
    #406987
    skeggylad
    think i got them back on ok did auto test got fault 4 flashes
    3 sequential operations by the Anti-flood Contacts of
    the Pressure Switch, due to Mechanically Blocked
    Opened Solenoid Valve or faulty Pressure Switch.
    #406988
    Like I said, fair chance… 😉
    skeggylad
    SOLVED
    Stripped the pipes they was all gunked up cleaned them all soapy water
    reassembled all tightened all up
    Stripped the Pressure switch cleaned contacts and the rubber diaphragm reassembled Self test was 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
    Now on a 29 minute cycle fingers crossed
    Thanks for your input 😉
    #406990
    skeggylad
    plus someone kindly put up a second hand one up for sale and left the wires on lol phewwww
    http://www.ebay.co.uk/itm/Hoover-HPE236 … 2c78b94a40
