HOOVER HNMF2605A FROST FREE FRIDGE FREEZER
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries HOOVER HNMF2605A FROST FREE FRIDGE FREEZER
  • #38145
    trainer
    HI, FRIDGE IS FREEZING EVERYTHING? HAVE TRIED CHANGING CONTROL THE SAME FAULT,THINK MAYBE SENSOR? IS IT REPLACEABLE?
    #257886
    tradesite
    Re: HOOVER HNMF2605A FROST FREE FRIDGE FREEZER
    Have you replaced the board with abrand new board?
    The fridge sensor is foamed into the back of the cabinet.
    Regards.
    Nigel.
    #257887
    trainer
    Yes, a new board fitted and still the same fault….suspected it would be foamed in. Can it be dug out and replaced?
    #257888
    andy2
    Yes they can be replaced – they are located 168 mm from top and 172 mm from LH side. I think the PN is 97061619 but check that.
    Cut out a square in the plastic, dig out the thermistor, cut the wires and patch in the new probe with bullitt connectors, refit and refoam. Cover repair with white tape.
    Andy 😀
