Hoover HNV270 Tumble Dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover HNV270 Tumble Dryer
  • #22184
    eV
    Tumbles, but no heat. Just out of one-year warranty and no parts/repair manual available from Hoover. Any suggestions, please?
    #193961
    Chriztopher
    Re: Hoover HNV270 Tumble Dryer
    either the heater element is blown or your heater control system is the problem.
    The heat control is usually a simple affair with ceramic bimetal snap switches ( thermostats )
    Unplug the dryer and remove the back cover and check.
    #193962
    eV
    Everything seems clean under the cover, the heat control you described (spades), and a round diode (thermostat?). Thanks. ?
    #193963
    eV wrote:Tumbles, but no heat.
    If you have ever been guilty of turning the machine off before the cycle has finished by itself? Then almost certainly you will need a complete Heater Unit fitting. 🙁
    There are 2 variants for this model (early & late production types) so in order to establish the correct part we would need the full Product number (12 or more digits beginning with 3??????????? 😉
    #193964
    eV
    HNV270-80 – Product Number 3100068 0439 0673
    #193965
    eV wrote:HNV270-80 – Product Number 3100068 0439 0673
    In that case the Heater part number is 04820062 and available by emailing these details to: spares@ukwhitegoods.co.uk
