Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover HNV380
- This topic has 5 replies, 2 voices, and was last updated 15 years, 6 months ago by
Allsorts.
October 4, 2010 at 1:49 pm #57688
Allsorts
ParticipantDoes anyone have a service manual for this model please.
George
October 4, 2010 at 2:47 pm #331963Martin
ParticipantRe: Hoover HNV380
Allsorts wrote:Does anyone have a service manual for this model please.
They don’t exactly do one George I afraid…there is a ‘Test’ manual for it though…is that of any use to you?…What are you wanting to know anyway?
October 4, 2010 at 3:50 pm #331964Allsorts
Test Manual would be great Martin. 🙂
The machine I have here tests ok on Heater, Cut-outs, motor, Door catch .. Run it on cold and it will run until end of program, but, run it on any heat program and it will run for 4-5 seconds then stop… Power remains at the Cut-outs and switches. It is as if a board supply part is shutting down.. I would say proberly heater relay but can’t be sure without testing it.
George
October 4, 2010 at 4:24 pm #331965Martin
Allsorts wrote:Test Manual would be great Martin. 🙂
OK…email me your email address (not on your website for some reason?) and I’ll shift it your way.:D
October 5, 2010 at 2:56 pm #331966Allsorts
Ecellent Martin thankyou… It seemed a bit like double-dutch to understand but then I assume it is a translation.
I have now ran a test but the test procedure came up with no error codes.. hence I presume it thinks that there are none.
Luckily I have another in the shop that has just been finished, so I ran the same test on that one to see if there were any differences at all… All I noticed is that during the original run on the drum, just before the error codes are produced, the drum stopped and did a reverse tumble, however, on the machine with the problem it did not. Therefore I can only summise that the problem is that there is no reverse tumble and that alone is causing the machine to halt.
Do you have an idea of which relay is which on the control board?
George
October 5, 2010 at 3:31 pm #331967Martin
Allsorts wrote:Do you have an idea of which relay is which on the control board?
Not a Scooby Doo George so maybe if you want to replaced a relay then change them all! 💡
