Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Hoover HNV380 excess fluff and air escaping
- This topic has 7 replies, 3 voices, and was last updated 8 years, 10 months ago by
tonyv.
June 7, 2017 at 3:29 am #91393
tonyv
ParticipantHi,
I have a Hoover HNV380 tumble dryer, recently followed your instructions to grease the pulley rollers to stop whining noise which worked very well.
However ever since then the door seems to have play (up down) when closed, a lot of fluff escapes as well as hot air out through the door edges. Is the door not aligned properly or does the seal need changing? I must add this happened immediately after I opened it up. Makes me think I did something wrong in reassembly.
Any help appreciated.
Thanks.
June 7, 2017 at 6:04 am #447917kaibart
ModeratorRe: Hoover HNV380 excess fluff and air escaping
It sounds like to me either the front panel or door seal are not fitted correctly more than likely the door seal
June 7, 2017 at 2:24 pm #447918tonyv
ParticipantRe: Hoover HNV380 excess fluff and air escaping
Right I’ve taken the front panel off and reinstalled the door seal. A lot of warm air still escapes from the top of the door. Do you reckon I need a new seal? Ive attached a video showing the play in the door.
https://www.youtube.com/watch?v=MlqNT2yI0LQ&feature=youtu.be
June 7, 2017 at 2:52 pm #447919timdowning
Doubt its the seal as the door is loose on the hinges.
The hinges have one screw longer on top & bottom hinge that screws into the inner plastic frame. Is that the case?June 7, 2017 at 3:08 pm #447920tonyv
Yes they both have one a small and large screw, I think the larger screw is the bottom one of each.
June 9, 2017 at 8:36 am #447921tonyv
Any ideas?
June 18, 2017 at 5:39 pm #447922tonyv
timdowning wrote:Doubt its the seal as the door is loose on the hinges.
The hinges have one screw longer on top & bottom hinge that screws into the inner plastic frame. Is that the case?Yes, included video that may help, would new hinges help?
https://www.youtube.com/watch?v=Uv0WcTSIM58Really could do with some help.
June 18, 2017 at 6:22 pm #447923timdowning
As you’ve already stated you thought it may be something you’ve done wrong in reassembly.
Hinges can’t suddenly get play in them… -
