Hoover HNW3135
  • #30312
    rocker
    This washer dryer blew a fuse,the machine now appears to be ok apart from no motor action, although customer tells me the motor tries to move on agitation cycle, but no spin, I have had a visual look at rear small pcb board no blown tracks…but not sure if its a board fault or motor, so as I dont have to strip the motor down, can anyone tell me the ohms readings between the motor plug terminals, and if the motor is ok which pcb will is likly to be faulty..
    any advice would be helpfull. cheers john
    #226727
    Re: Hoover HNW3135
    Can’t find a HNW3135 on my list….? Is it a HNWL3136 Washer Dryer?
    Anyway, not to worry on that (unless you can tell us the 8 digit product code instead beginning 3???????)
    Chances are that the TR1 triac has blown on the Coreboard? (That’s the big one clamped to the aluminium heatsink by the way)….worth a look 😉
    #226728
    rocker
    Re: Hoover HNW3135
    Martin, the model is HNWF3135 prod code 3100632
    where can i purchase part triac !! how do i test part, sorry for lack of knowledge on electronic parts.
    cheers John.
    #226729
    BobHope
    Re: Hoover HNW3135
    Hi John,
    i have emailed you some info
    Bob
