hoover hnwf 7137 11 flashes
  • #89953
    mackos
    Hi Guys
    Went to look at a Hoover HNWF 7137 washer dryer. I’m getting a fault code of 11 flashes. Seems to fill,heat,empty & spin ok. Haven’t tried putting it on drying. Anyone know what might be causing this fault. Thanks Mack.
    #443117
    Re: hoover hnwf 7137 11 flashes
    Did you check the error codes thread Mack? In there it suggests the dryer module might be the issue. 😉
    #443118
    mackos
    Hi Martin
    Thanks for the reply. Yes I did check the error code thread. As we know sometimes the fault lies elsewhere, just thought it might be a known fault. Have found how to self diagnose which I will try when I go back for another look.
    Thanks again Mack.
    #443119
    kaibart
    Check that the dryer duct is clear and the valve operates on the dry cycle if that’s ok it probably pcb kai
    #443120
    mackos
    Hi Guys
    Just to let you know the outcome of this job. It was broken t/stat wires on top of the dryer manifold, reconnected now all working ok.
    Thanks guys. Mack.
