hoover HNWF3135 not drying
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hoover HNWF3135 not drying
  • #40086
    My washer dryer has stopped drying.
    I opened it up and noticed the heater element does fire up but the fan does not cut in to blow the hot air into the tub. I assumed it was a faulty fan motor, bought a new motor and with great hassle got the fan off and took off the old motor then fitted new and replaced fan – still does nto cut in. So guess it must be the power not getting to the fan motor? Now I’m stuck, presumably there is some sort of thermostat that may need replacing which tells fan when to start/stop? I know there is an overheat reset button on top of the heating unit (often have to reset as machine is badly designed) but not sure if it is this that needs replacing or somethign else? Any help appreciated.
    #264701
    helo_75
    production number please
    usually starts 31….and is 16 digits long
    sounds more like a pcb/dryer module faulrt depending on build date
