HOOVER HNWL 6136
  • #25361
    senseib
    Got new 41013996 module for this m/c that needs configuring desperately need Help pleaseee. ๐Ÿ˜ฅ
    #205564
    Re: HOOVER HNWL 6136
    I’d have gone for 09200452 – core board, preprogrammed. Haven’t got a clue how to configure yours……. Sorry.
    helo_75
    urrghh
    hoverhave a hand held terminal to configure those…
    and they dont supply them to trade
    but theyll programme urs for ยฃ95 ๐Ÿ˜ˆ
    typical
    #205566
    Last “pre-configured” board I bought (not this one) was about ยฃ35 plus VAT, which wasn’t too bad really.
    helo_75 wrote:and they dont supply them to trade
    Indeed they don’t, and in fact they come as a Programming Unit Kit (Pt No 4900727) Which comprises of an Interface Box, Mains Cable, Serial Cable, Ribbon Cable, Shunts and an extracting tool. Software (downloaded from the Internet) for each model’s coreboard can be loaded (Winzipped files) and programmed. All products (w/m’s, D/w’s, Ovens etc) can be configured, re-programmed and fault diagnosed using this equipment. ๐Ÿ˜ฏ
    The same sort of apparatus is now being used by most whitegoods manufacturers (currently Hoover, Indesit, Miele supply to their staff only) that do not pre-programme their module/interface boards and eeproms. Which is a worrying prospect for all independents, work providers and insurance companies whenever this type of component failure occurs.
    Technology gone stark raving mad if I am any judge? ๐Ÿ‘ฟ
    #205568
    senseib
    Me thinks there is a conspircy a foot and it affects us all!!!!
    If anyone out there can advise please do?
    #205569
    Penguin45 wrote:09200452 – core board, preprogrammed.
    Is what you need………
    senseib
    Will get onto the trade parts people tomorrow
    Thanks for the advice chris.
    Brian.
    #205571
    Martin & Chris,
    I wonder why in this forum nobody talks about the way to bypass this kind of “unrespect” ๐Ÿ‘ฟ from manufactures for our job.
    I’m talking about anybody (who had a little knowledge about computers and electronics in order to do some job to reprogram one EPROM) can discuss and interchange files (bin’s). It isnโ€™t so hard to dismantle one chip and run one computer program. Iโ€™ve spoke from my position, with one little and easy to made programmer which can be find free on internet (or more easily to buy). So I managed with Whirlpool/Bauknecht; Ariston/Indesit; Hotpoint. I have also some files from Hoover/Candy like here related. But in this case I didn’t do this kind of job on Hoover in order to see its results because I did not need.
    What I wanted to say is that itโ€™s more cheep and quickly, in order to complete one job to buy one (EEPROM) programmer and using all people to share files found on the jobs instead to buy another pre-programmed programmer or module from suppliers.
    Can also buy such tools: from Whirlpool so called SAM; from Indesit/Ariston so called Hardware Key Seriall together LB Sat and WM Doctor and so on. But like Martin said is like just for them own trade.
    #205572
    senseib
    Need to order pre-programmed core board for this machine.
    Chris indicated core board 09200452 but espares web page shows board 09200602 for this machine. (Hoover website useless) Already bought wrong board once!
    Is it a case were either board will do – If not which one?
    Help much appreciated!
    Brian.
    #205573
    You weren’t seriously going to buy it from espares, were you?
    My tech info came up with the number – Martin might like to double check in the morning – he has access to a bit more than I do.
    senseib wrote:If not which one?
    09200452 is the correct one. ๐Ÿ˜‰
    #205575
    senseib
    Thanks Martin,
    Only use espares to check corresponding model numbers. But I do have a problem because qualtex, masterpart & homespares (the 3 trade ones I use!)
    dont appear to stock this one.
    Any suggestions? – regarding buying the board of course!
    #205576
    Most wholesalers not stocking it is often a sign there is not call for one? ๐Ÿ˜•
    If you phone Masterpart, maybe they can tell you a likely delivery date?
