hoover hnwl 6136
  • #34358
    eng14
    hallo i went to this w/d today,door lock light flashing,wont start need module and slave timer part nos to order also candy cn120 requires module any info welcome thanks richard 🙂
    #242293
    timdowning
    Re: hoover hnwl 6136
    On the HNWL6136 have you checked the small switch behind the start button? Door lock and door hook/handle are weak points on this model. Which could give you a no start fault.
    Recently I’ve been needing a few boards for various Hoover machines and have started ordering direct from Hoovers spares Dpt. Prices are still generally cheaper than Connect. My other wholesalers don’t have the boards in stock.
    #242294
    CN120 board – programmed – 97922843
    Date code and full model number required for the other one.
