Hoover HNWL 6136 – 80 washer/dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HNWL 6136 – 80 washer/dryer
  • #50092
    jontymox
    Good morning all,
    Wondering if anyone has come across the above m/c not drying?
    I’ve checked the usual suspects… twin elements appear fine, and giving decent ohms resistance readings.
    Also TOC’s appear ok also, and tested thermistor, which is part of this unit.
    This gave a good ohms reading, and altered when warmed up a little.
    Hope someone can advise, as I’m fairly new to this business.
    jontymox
    #303449
    loopey
    Re: Hoover HNWL 6136 – 80 washer/dryer
    these m/c have a seperate pcb for the dryer side its located at the bottom rear of m/c , probs just a dry joint , ..
    is it showing any flashing lights , count the number of flashes , for fault code can send you some stuff iff you like ……….
    phil
