Hoover HNWL6136S : low dryer heat?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HNWL6136S : low dryer heat?
  • #25451
    trusted
    Just been looking at a Hoover HNWL6136S.
    The fault was no dryer heat.
    I reset the L/H heater TOC and tested. I got some heat but it only used 4.9 amps. I took the wires off both elements and they were both closed circuit.
    Is 4.9 amps correct ?
    All help appreciated.
    #205881
    jeremy
    Re: Hoover HNWL6136S:low dryer heat?
    that would be about 1.1kw then, was the wattage of the element marked on it ?
    #205882
    MickGeorge
    Re: Hoover HNWL6136S : low dryer heat?
    That’s about what I would expect as washer driers are condeser driers and only use low wattage as they recirculate air..
    Mick
    #205883
    trusted
    jeremy wrote:that would be about 1.1kw then, was the wattage of the element marked on it ?
    Sorry but I didn’t open up the dryer housing, so I can’t tell you.
    #205884
    timdowning
    Side issue, did you check for blockages in condenser ducting and blower motor? if these are blocked the TOC will trip again due to poor air flow.
    #205885
    trusted wrote:Is 4.9 amps correct ?
    On high heat tumble dryer with fan, valve, heaters and pump running you should have a reading of 6.04amps (low heat = 3.80amps)
    Check your email….. 😉
    #205886
    trusted
    Thankyou Martin very much. That will help me if I get a recall.
