Can anybody help got one of these no heat, i’ve checked the element, looked at the module for dry joints, it seems to fill okay and wash i noticed there is a pressure switch situated in the bottom feed pipe whch is wired in series with the heater does anybody know if these cause any problems chhers JJ.
Hi Johnnyj,
it is possible to check pressure switch.Disconnect wires and connect the other ones connected with Your ohmmeter.Start the machine and wait for spray pump start.If You read 0 ohms- pressure switch is OK.
Also,You shold check wires continuity from PCB and door MS to heater and pressure switch.Heater releay on PCB,too.
