I’m struggling with this oven. No heat at all and oven fan doesn’t run on any setting. Cooling fan runs on certain settings and that’s all. No display on the timer so thought easy timer problem. I by-passed the timer and still nothing. All elements ok. Selector switch checks out ok with multimeter. OHC has continuity and what I presume is the cooling fan over run stat is the only stat open circuit at room temp. Can’t think what to try now.
Does anyone have access to a wiring diagram for this, or a similar oven, so that I can follow it through? Any thoughts would be much appreciated.
Graham
