Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hoover hp13
- This topic has 7 replies, 6 voices, and was last updated 18 years, 5 months ago by
delta01.
October 30, 2007 at 4:07 pm #31798
delta01
Participantgot new board from connect pre programmed. selected prog. pressed start, indicator lights but nothing else , original fault motor action but no spin and did not fill for quite a while after setting on a wash . any help gratefully recieved
October 30, 2007 at 4:30 pm #232540Martin
ParticipantRe: hoover hp13
On the old board, were any of the triacs blown?
October 30, 2007 at 6:48 pm #232541delta01
i havent tested them i will check that though. strange thing about this is the original fault was just a bra wire in tub , i removed the heater to extract it and all seemed ok, later the customer said it had not spun so after a quick look over i thought best to bring it in , concluded it must be the board
October 30, 2007 at 7:30 pm #232542helo_75
Participantid be cheackin the heater/ terminals
not impossible its summink uve done?
November 2, 2007 at 10:28 pm #232543delta01
well it seems that there are more than one board for this model as a tel call to connect revealed, surprized that yet again none of the engineers on this forum could offer that solution, most questions i have submitted has generally drawn a blank or some wrong suggestion, i’m sure some genuine help has been offered by some ,but get the feeling there is a reluctance by others to offer genuine help ,
November 2, 2007 at 11:58 pm #232544iadom
ModeratorRe: hoover hp13
Personally I take serious umbrage at that remark. There are times when questions are posed that I honestly do not know the answer to, other than that I, along with virtually every other member who posts on a regular basis does their level best to answer peoples questions, they do however say that “God helps them that help themselves”.
I can honestly say that I get no feeling of any reluctance to help, even when certain individuals would seem to be in the wrong profession ( no names, no pack drill ) help is still offered willingly.
Hoover spares info is readily available online for those who take the effort to seek it out.
Most people would assume that an engineer of any merit would have availed himself of that information before ordering expensive parts such as PCB’s 😉
November 3, 2007 at 1:01 am #232545Penguin45
If you’d put up the serial number as well as the model, no doubt we would have instantly managed to summon up the correct part number for you…..
What are we? Mind readers or something?
We the Willing
Led by the Unknowing
Are doing the Impossible
For the Ungrateful.We have done So Much
With So Little
For So Long
We are now Qualified
To do Anything
With Nothing.‘Course, you could just have abdicated all responsibilty and sent for Hoover and let them rip off the customer.
Good luck next time you need help.
November 3, 2007 at 2:12 pm #232546timdowning
Why do you keep using the site if you find it so useless?
I personally find this site very useful. You may not get all the answers you want but nothing in life is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}.
Chill out a bit a stop being so paranoid.
