Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hoover hp13
- This topic has 8 replies, 2 voices, and was last updated 18 years, 4 months ago by
delta01.
November 22, 2007 at 5:54 pm #32439
delta01
Participanton spin only does tumble/reverse action for a few minutes then stops with pre wash & start lights flashing occasionally , have tried new module no change, allso tried motor. Its only two yrs old. strange thing is it allso takes a while to start filling on wash
November 22, 2007 at 6:28 pm #235146timdowning
ParticipantRe: hoover hp13
count the flashes in a 15 second interval. This will relate to the fault codes for the Nextra range. (in known error codes).
November 24, 2007 at 12:57 pm #235147delta01
i got three flashes according to code book this is pump timed out, however. the machine is empty i tried changing pressure switch to no avail, is it possible for the spin potentiometer to cause this fault ?
November 24, 2007 at 5:03 pm #235148timdowning
Not known of the spin ‘pot’ to cause this fault. When you say it takes a while to fill on the wash does it fill on the prewash side before the main wash side of the draw?
November 24, 2007 at 5:12 pm #235149timdowning
p.s Is this the same HP13 that you had trouble with the wrong modlue?
November 25, 2007 at 3:39 pm #235150delta01
yes the very same, i got the correct module eventually (digital)
i will check how it fills soon and get back to you, thanks for your inputNovember 26, 2007 at 2:32 pm #235151delta01
hi again it fills through the valve nearest to middle of machine , ie the right hand side of the double valve looking towards back after about five minutes of motor action
November 26, 2007 at 4:44 pm #235152timdowning
…five minutes of motor action
So no water goes in the machine at all until five minutes into the cycle?
If the valves are ok and the heater etc, it must be a wiring issue as you have eliminated board and motor.
(have you tested the valves with a meter?)
November 27, 2007 at 6:35 pm #235153delta01
hi again , yes both valves read ok on ohms range about 33.5
this fault developed after removing the heater to extract a bra wire , although the customer didnt report the fault for about a week afterwards probably just coincidence but baffling !
