I fitted new motor brushes to this machine a couple of weeks ago, all seemed well at the time.
Now it won’t start any programme, set it to wash, rinse or spin and the drain pump kicks in for a split second then cuts out. If you switch it on and off it will keep doing this. ❓
This pump has a built in overload so tried a different pump but that did the same.
Also tried a selector switch to no avail.
Any pointers or is my guess of a PCB problem the likeliest scenario?
