If this is the newer model which has a small timer/selector and a module next to it then its the module at fault. (99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure). The only timer/selector faults I’ve had are when the programme starts ok and the selector/timer clicks round as it fancies.
thanks lads thats what I thought Ill keep you posted its only the second one of this model Ive seen (first one had edge block off) although its a newer one they still have not improved the hose arrangement to prevent rubbing pressure hose /vent hose 🙄
