Hoover HPB 145-80 Slow cycle issue
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover HPB 145-80 Slow cycle issue
  • #93266
    The Equalizer
    Hi all
    I have a Hoover HPB 145-80
    S/N. 31001186
    I have had this Washing machine for quite a few years now and its been pretty reliable.
    I replaced the brushes on the Motor 6 months ago thanks to the advice and parts from here. And its been fine since.
    However recently though it seems to take ages to do its usual 29 min 40 degree wash.
    Sometimes it takes over 2 hours and you think its stuck, then as you walk past it, the drum turns, then stops.
    When it runs it runs flawlessly, no noises or grinding. Its just slowed down.
    So, once again I ask the experts,
    what parts do I need?
    Is the part available?
    Is it worth doing?
    Or should I be looking for a new machine.
    Simon
    #453738
    Re: Hoover HPB 145-80 Slow cycle issue
    Most likely reason is that it is’nt heating the water. Check the heater.
    #453739
    The Equalizer
    Hi Martin
    Thanks for your advice mate.
    I’ll have to youtube that one, as I’m not sure how to.
    Many Thanks
    Simon
    #453740
    The Equalizer
    Ok just youtube’d it.
    I need to dig my multimeter out.
    Will post back with results.
    Many thanks again.
    Simon
    #453741
    The Equalizer
    Ok just stuck my meter on the heater terminals.
    On my low ohm setting of 200, I get a reading of around 300 from the terminals.
    Whatever that means.
    #453742
    The Equalizer
    As a follow up
    I have replaced the Heating Element and Temperature sensor. (worth the gamble for less that £30)
    It appears to have made no difference.
    So, what is the next thing to look at before I think “chuck it and get another”
    I was reading the article on “Washing Machine spin out of balance protection” and wondering if that could be a possibility, it does sometimes sound like the Good lady may have put a brick in the wash, even though its not overloaded.
    Could a dampener be the issue?
    Simon
    #453743
    kaibart
    There is 2 possible causes is the pump emptying the water out ok if so we can rule that out. The other thing is the selector switch which selects the programme can be faulty 22 position v selector they do go faulty a lot kai
    #453744
    The Equalizer
    HI Kai
    It pumps out the water ok? So could be the selector possibly.
    Any chance of a PCB issue?
    #453745
    The Equalizer
    Having said that it pumps out water ok,
    I opened up the Pump Trap, and a load of water came out?
    So maybe not?
    #453746
    The Equalizer
    The Pump needed, if it is the pump. Would be this one according to the store
    https://shop.ukwhitegoods.co.uk/4900222 … drain-pump
    Part no SKU: 49002228
    Just wondered if there is a cheaper compatible part, in case its not the pump.
    #453747
    It’s never a good thing to throw parts at the machine. That can get costly and not solve the underlying problem anyway.
    Now before you fit a new pump, check the pump impeller to see if it has any lateral movement indicating its bearings are worn. Check the drain outlet hose especially if it couples with the sink drain. Check the main sump hose especially the ball valve in it. A process of test and eliminate before fitting new parts the best way forward,
    #453748
    The Equalizer
    Thanks Martin
    I appreciate your advice.
    But seeing as the machine was 7 years plus old.
    I decided to buy new.
    I agree that throwing parts at a machine isn’t a great idea. but I figured it was worth a £30 gamble.
    Didn’t pay off this time and. next time I will check all the areas you have suggested.
    Thanks ever so for your help.
    Bought a second hand Beko to get me by for the next year or so.
    Regards and Thanks
    Simon
