Hoover HSW110m
  • #18050
    DAF52
    My Hoover HSW110m washer/dryer has stoped fast spinning with a load in but will when empty. any ideas????
    #177520
    Re: Hoover HSW110m
    Either you’re trying to spin an out of balance load or the motor brushes are worn and playing up?
    If the latter, click the link below for a local repairer to sort it for you 😉
    #177521
    dan0k5
    Re: Hoover HSW110m
    I had the same problem on my hoover washer dryer, the same as yours it took the repairman two weeks to find the problem, he replaced, the timer, the bearings, the module, the armature the motor, the belt, the brushes. after replacing all of these the fault still occured, the repairer tried on the off chance giving a quick blow down the drain pipe, it cleared the pressure switches or whatever theyre called and it was back to normal.
    Anyway the problem ahs never occured since one year on touch wood 😀
    Just thought i’d have a quick input
    Hope you dont mind
    #177522
    Re: Hoover HSW110m
    dan0k5 wrote:I had the same problem on my hoover washer dryer, the same as yours it took the repairman two weeks to find the problem, he replaced, the timer, the bearings, the module, the armature the motor, the belt, the brushes. after replacing all of these the fault still occured, the repairer tried on the off chance giving a quick blow down the drain pipe, it cleared the pressure switches or whatever theyre called and it was back to normal.
    Hope you dont mind
    I hope you are not still using the same repairman. 😯 😉
    #177523
    dan0k5
    Re: Hoover HSW110m
    The Repairman was sent under Domestic and General insurers, should he not have blown down the drain hose ?
