Re: Hoover hurricane light – Very loud and high pitched whin
Hi stuart
The noise is more than likely coming from the brushroll,not difficult to get at really
Turn machine upside down, remove all the screws securing the black plastic surround of the brushroll, including the long part at one edge which covers the belt..
Remove brushroll and spin around with your hand to check for any noises
Off hand i cant rembee if the side caps are removable to get at the bearings, if not its a new brushroll needed. Whilst the brush is out you can turn the machine on and check that the sound is ot coming from the motor…if it is my advice is to bin it, as the cost of a new motor is almost as much as a new machine!
Hope this helps
